Can't activate the 2.4 GHz connection on my modem
  • July 4, 2023
  • 133 keer bekeken
I'm trying to connect a camera that only works with 2.4ghz but i do not have 2.4ghz only 5ghz how do i acitvate 2.4ghz. I tried to login via 192.168.2.245 but it says password wrong when i use the admin password from the back of the router. KPN box 12b
Beste antwoord door Cappuccino2
Create an extra 2.4Ghz wifi following these instructions
Try login in using this link http://192.168.2.254/2.0/gui/#/
  • July 4, 2023
http://mijnmodem.kpn
  • July 4, 2023
Not helpfull
  • July 4, 2023
Not helpfull
You need to connect an Ethernet Cable from the computer to a LAN port on the modem.
Cappuccino2
Helper
  • July 4, 2023
  • July 4, 2023
Ja deze link is goed ,kan ook met wifi ingelogd worden.
