Cannot log into mijnmodem.kpn in Chrome or Edge on desktop
  • mei 30, 2024 5:45 p.m. UTC
  • 91 keer bekeken
I’m able to log into mijnmodem.kpn on my iPhone.
On my desktop I cannot log in using Chrome, Edge, or Brave. I am able to log in using my desktop in Firefox.
Is there a fundamental problem between KPN and Chrome? Can you fix it so I can manage my router using whatever browser I prefer?
What kind of modem do you have in use @JT8392? Have you tried approaching the interface directly without the redirect at http://192.168.2.254/?
  • jun 3, 2024 3:15 p.m. UTC
I found the solution. The problem was my ad blocker. I turned it off and now the site works fine.
That's great! I'm glad you found a solution. Thank you for sharing it.
