How can I change DNS settings for DHCP in LAN on my Box12?
  • jan 8, 2024 5:06 p.m. UTC
  • 151 keer bekeken
Hello, there is a field for DNS server IP in Thuisnetwerk - DHCP, however it’s inactive. Why? Is this locked on purpose by KPN?
Beste antwoord door wjb
If you uncheck the tick box DNS-proxy gebruiken on the screen below then you can enter the DNS servers to be used.
2 reacties
  • jan 8, 2024 6:02 p.m. UTC
  • jan 8, 2024 8:47 p.m. UTC
Thanks!
