How can I change DNS settings for DHCP in LAN on my Box12?
  • January 8, 2024
  • 150 keer bekeken
Hello, there is a field for DNS server IP in Thuisnetwerk - DHCP, however it’s inactive. Why? Is this locked on purpose by KPN?
Beste antwoord door wjb
If you uncheck the tick box DNS-proxy gebruiken on the screen below then you can enter the DNS servers to be used.
2 reacties
  • January 8, 2024
  • January 8, 2024
Thanks!
