How do I change the KPN Box 12 language to English?
  • jul 28, 2025 11:14 a.m. UTC
  • 204 keer bekeken
as have being asked 9 months ago:
I wonder when would the language option been implemented or if it has already been implemented, as  promised within above thread:
" The next update should bring some more language options. You can subscribe to our product updates to get a notification when we publish an article about it."
many thanks in advance for your concern and support!
PS: my V12 has still the firmware V12.C.24.05.08, it seems the latest version is
Yet I cannot see any place within the router's interface for update.
Please advise.
Beste antwoord door BruisTablet
Not when version on V12 is V12.C.24.05.08 or older. Needs newer version then it will be selectable.
  • jul 28, 2025 11:36 a.m. UTC
PS: my V10 has still the firmware V12.C.24.05.08, it seems the latest version is
Je hebt een KPN Box 12. En geen v10.
Ik heb wel een Experiabox v10. En links onder heb ik:
Maar dat is alleen zichtbaar op de pc/laptop. Of op de mobiel in desktop weergave.
  • jul 28, 2025 11:58 a.m. UTC
​@Marlon92 bedankt voor uw correctie. Ja ik heb KPN box v12.
Maar heeft de KPN Box V12 geen optie voor taal naar Engels  of update
BruisTablet
Topper
  • jul 29, 2025 10:32 p.m. UTC
Leen59
  • jul 29, 2025 11:05 p.m. UTC
Check the firmware
Hi ​@DannyJohn, welcome to the community. I'm not sure which languague you prefer since you used both English and Dutch, but I'll pick English because you started with that 🙂
As the others mentioned, it was added to the firmware, in a later version than you have. It will be updated automatically, at a later moment. It might have already been updated, what version do you have now?
