I use my own router (VLAN 7 etc). What do I need to plug the telephone?
  • October 31, 2023
  • 141 keer bekeken
EDIT - error in title. Should be “VLAN 6”.
Dag Iedereen.
Vergeef me alsjeblieft. Ik leer Nederlands.
Het maakt het lastig om op het forum te zoeken.
I have Glasvezel and I use my own router (VLAN 6 and PPoE configured - all working well). I am using a Ubiquiti Gateway but will soon change to Opnsense on a new device.
I also have the phone service from KPN.
How can I plug my fixed phone in?  Do I need special settings for VLAN / SIP etc?
If you can share keywords to search for it would be really helpful.
Dank u!
Beste antwoord door wjb
You will need a separate VoIP ATA to connect your telephone.
I have an EdgeRouter 4 as router and use a Gigaset N300A IP for my telephone.
There is no separate vlan involved for the telephone.
2 reacties
  • October 31, 2023
  • October 31, 2023
Dank u!
