I want to skip using the KPN modem
  • dec 2, 2024 11:45 a.m. UTC
  • 149 keer bekeken
Hi ,
I wanted to ask how can I skip using the KPN modem, I have a fiber connection and want to avoid using the standard kpn modem because of security and reliability concerns. I have my own networking gear that I want to connect to the fiber adapter directly.
My question is : did anyone manage to get KPN to change their modem’s mac address so that another one can be used ?
Thanks
bnh
Forum|alt.badge.img+12
  • dec 2, 2024 11:47 a.m. UTC
Are your using the KPN ONT, where the modem should be connected with a LAN cable or do you put the fiber cable direct in your gear ?
  • dec 2, 2024 11:58 a.m. UTC
There is no need to change the MAC address of the router you want to use.
If you don't have television from KPN it is very simple, just make sure de router uses a pppoe connection on vlan 6 to connect to the Internet, the login credentials may be anything.
If you doe have television form KPN, please read the topic below.
  • dec 2, 2024 12:07 p.m. UTC
Hi both , thanks for the quick reply. I’ve managed to find the solution on this forum. And indeed it was the case to set the vlan id to 6 and i didn’t know the username and pw (tried copying them from the kpn router but they didn’t work).
Thanks again for this info , this has completely changed my day :D
Take care
I see you received excellent advise in this topic ​@dmikee! Good you managed all the outstanding issues. For future readers there is also a dedicated page for this subject. If we can assist you further let us know!
  • dec 3, 2024 6:29 p.m. UTC
Hi ​@Remco van KPN thanks for the follow-up and also the page. I would have a suggestion to make sure that this is known by your customer service dept because i called them before finding this forum and they didn’t have any clue that this is possible. She told me that it can’t be done with KPN.
That's unfortunate ​@dmikee, I agree that the page in question should be the bare minimum. I'm really sorry that it wasn't communicated properly. Feel free to post a followup topic if you have any additional questions.
