IPv4 port forwarding not visible in webinterface
  • December 13, 2024
  • 68 keer bekeken
Péter Baán
Nieuwkomer
Hey guys! I am trying to set up a Minecraft server, I am used to doing it on IPv4 and my Raspberry PI supports IPv4 better than IPv6. However when I log into the KPN admin interface, I can only see port forwarding for IPv6.
Do you guys have the same admin interface as me, because some older discussion about port forwarding had stuff which are simply not there for me.
Hi Peter! Did you manage to setup your Minecraft server in the end? Could you eleborate which modem you have in use? And could you also check the firmware version?
Péter Baán
Nieuwkomer
  • January 16, 2025
Hey Remco! I did not manage to set it up yet, I have an Experia Box v10A, with the firmware version v5.00.60 build51.
Thanks in advance
Unfortunate you should check the following article in our knowledge base:
Or maybe a member of our community has a similar setup and can assist you further.
