My Box 12 router restarts itself for no apparent reason
  • sep 13, 2025 11:44 p.m. UTC
  • 172 keer bekeken
Hello, wonder if someone can assist with my issue, since 2 weeks ago ever couple of days my Box 12 router restarts itself for no apparent reason,
All lights go off and start the start process, when the last light turns solid green (WiFi) I all lights go black again before the center light goes red and the process stars once again.
i have tried everything, but seems that there is no solutions, I managed to turn off the WiFi via browser, which aleros the router working for a couple of days until the process starts once again.
Beste antwoord door Leen59
Looks like you have a defective power adapter. Check this:
Leen59
  • sep 14, 2025 12:06 a.m. UTC
Hoi ​@Carlos_115, welcome to the community. I agree with Leen, it sounds like the power adapter has an issue. There are some adapters that can cause this with the Box 12, we have a special page on our website where you can check if yours is on of them, and you can request a new one there aswel: Stroomadapter Box 12 vervangen. The page is in Dutch, but it should work with Translate.
  • sep 17, 2025 5:32 p.m. UTC
Hey Leen
Thanks for the heads up, you were right, I swapped the power cable on a KPN store and problem solved. I really appreciate your indication and the link shared. Also thanks to Jasper!
Regards
That is good to hear, I'm glad it's solved now ​@Carlos_115 🙂 If there is anything else we can help you with, don't hesitate to ask.
