Ik probeer de IPv6 configuratie werkend te krijgen op de Mikrotik RB5009. Dit lukt niet echt, hij ontvangt geen IPv6 adres (via DHCPv6 Client).
/interface vlan
add interface=sfp-sfpplus1 name=vlan1.4 vlan-id=4
add interface=sfp-sfpplus1 loop-protect=off name=vlan1.6 vlan-id=6
/ppp profile
set *0 only-one=yes use-compression=yes use-ipv6=no use-upnp=no
add name=default-ipv6 only-one=yes remote-ipv6-prefix-pool=*0 use-compression=yes use-upnp=no
/interface pppoe-client
add add-default-route=yes allow=pap disabled=no interface=vlan1.6 keepalive-timeout=20 max-mru=1500 max-mtu=1500 name=pppoe-client profile=\
default-ipv6 user=1234@internet
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
/ipv6 nd
add advertise-mac-address=no disabled=yes hop-limit=64 interface=bridge
/ipv6 address
# address pool error: pool not found: 0 (4)
add address=::1 from-pool=0 interface=bridge
/ipv6 dhcp-client
add add-default-route=yes interface=pppoe-client pool-name=0 pool-prefix-length=48 request=prefix use-peer-dns=no
De DHCPv6 client blijft hangen op: “searching...".
De IPv6 firewall rules die hierboven vermeld staan, staan bovenaan in de firewall. Ik zie namelijk ook geen packets(counts) binnenkomen op die rules.
