Wat betekent dit in de servicelog van het modem?
  • October 1, 2023
  • 186 keer bekeken
Ik heb al verschillende keren de modem gereset naar fabrieksinstellingen zonder resultaat.
1970-01-01 00:00:15 Dhcps:SendAck, Dev[8c:85:80:fa:ae:76], ip [192.168.2.2], lease [86400]
1970-01-01 00:00:15 Dhcpc:Recv Packet,ACK, Lease of 10.202.100.217 obtained, lease time 3600
1970-01-01 00:00:16 TR069:Start to init.
1970-01-01 00:00:16 TR069:Init success.
1970-01-01 00:00:17 Dhcps:SendAck, Dev[38:1f:8d:76:4a:23], ip [192.168.2.3], lease [86400]
1970-01-01 00:00:18 PPP(eth_route):start Discovery
1970-01-01 00:00:18 PPP(eth_route):send PADI and wait for PADO 1 sec
1970-01-01 00:00:18 PPP(eth_voip):start Discovery
1970-01-01 00:00:18 PPP(eth_voip):send PADI and wait for PADO 1 sec
1970-01-01 00:00:18 PPP(eth_route):recv PADO
1970-01-01 00:00:18 PPP(eth_route):send PADR and wait for PADS 5 sec
1970-01-01 00:00:18 PPP(eth_route):recv PADS,SessionID is 7910
1970-01-01 00:00:18 PPP(eth_voip):recv PADO
1970-01-01 00:00:18 PPP(eth_voip):send PADR and wait for PADS 5 sec
1970-01-01 00:00:18 PPP(eth_route):Starting negotiation on ppp0
1970-01-01 00:00:18 PPP(eth_voip):recv PADS,SessionID is 7913
1970-01-01 00:00:18 PPP(eth_voip):Starting negotiation on ppp1
1970-01-01 00:00:18 PPP(eth_route):PAP authentication succeeded
1970-01-01 00:00:18 PPP(eth_route):set local/remote IP: [IP verborgen]/195.190.228.108; dns: 195.121.97.202/195.121.97.203 on ppp0
1970-01-01 00:00:18 PPP(eth_voip):PAP authentication succeeded
1970-01-01 00:00:18 PPP(eth_voip):set local/remote IP: 10.160.224.234/195.190.228.108; dns: 0.0.0.0/0.0.0.0 on ppp1
1970-01-01 00:00:19 Dhcps:SendAck, Dev[4c:1b:86:81:14:b9], ip [192.168.2.8], lease [86400]
1970-01-01 00:00:19 Dhcps:SendAck, Dev[4c:1b:86:6e:c0:98], ip [192.168.2.150], lease [86400]
1970-01-01 00:00:23 Dhcps:SendAck, Dev[38:1f:8d:76:4a:23], ip [192.168.2.3], lease [86400]
1970-01-01 00:00:25 TR069:Start to create a new session.
1970-01-01 00:00:26 TR069:Session create fail,net error.
Dit lijkt mij gewoon het opstarten van een verbinding met de relevante onderdelen in ons netwerk. Ervaar je momenteel problemen @Anoniem.? Als ik ik iets kan doen laat het dan weten!
  • October 11, 2023
Is het dan normaal dat het opstarten van de verbinding in 1970-01-01 begint ?
RBxx
  • October 11, 2023
Als je het modem reset zal ook de interne klok op "nul" gezet worden. 1970-01-01 00:00:00  is het "nul" moment. Op een zeker moment in de opstartprocedure wordt contact gelegd met een tijdserver en zal de tijd weer goed staan.
