What would be a good alternative for dual bonded dsl (BVDSL) modem?
  • October 7, 2024
  • 68 keer bekeken
Hello all,
sorry for using English, my dutch is very poor at this stage yet.
I have a question.  I want to have an Wifi 6, but with my bonded VDSL I have really not much choice from KPN. Either I will have 200mb (2x100) and wifi 5 (with fritzbox 7583) or I can get newer fritzbox and only 100 mb from one line.  Are there some alternatives from TP Link, or other makers? I also don't want to spend a “milion coins” for a new device.
2 reacties
Hello @Waldi, one of the alternatives could be a Zyxel VMG4005-B50A. When you use this product keep in mind you need a extra router, because the Zyxel is only a modem. If you use the Zyxel, you can start using an extra router which uses Wifi 6.
  • October 10, 2024
Well, I found that solution by myself, I would have rather one device with both fuckctions. otherwise I don't have to change my current router, just switch off WiFi and get something with wifi6 in the chain.
