Activating a prepaid sim while being abroad
  • February 9, 2025
  • 8 reacties
  • 146 keer bekeken
Hi there! I'm abroad atm and unfortunately I can't activate my SIM. Could you please activate the SIM, as I need this activated the soonest possible? Thanks in advance ☺️
Thanks ​@Chris_tos! I've activated the sim for you, so you should be able to use it now. If not, restart your phone and try again, then it'll be good to go.
And thank you ​@RBxx for the assistance :)
8 reacties
RBxx
  • February 9, 2025
Hi ​@Chris_tos
You could activate this yourself, but only when you are in the Netherlands, connected to the KPN network.
Place your 06-number and SIM card number (ICCID) in your profile . Use the field "Persoonlijke opmerkingen" and save your input by pressing "Sla wijzigingen op".
Report here when this is done, then I'll bring your question to the attention of the KPN moderators.
  • February 10, 2025
Hey there,
unfortunately I’ll be on the Netherlands in a couple of weeks, but I need the sim activated asap.
I saw on another discussion that a SIM card have been activated from the customer service, as the person was abroad as well. That’s why I asked for an activation.
thanks !!
Hi ​@Chris_tos, can you add your details to your account, as ​@RBxx adviced? I don't see them there now. If you add this information and let me know here, then I can help you with activating the simcard.
Hi ​@Chris_tos
  • February 10, 2025
Mobile phone number updated :) where could I find the iccid number?
RBxx
  • February 10, 2025
You can find this number on the SIM card itself or on the plastic card in which you received it.
  • February 10, 2025
Updated as well :)
  • February 10, 2025
Thank you very much both! 😉
