Cannot activate sim-card abroad
  • jun 10, 2025 7:31 a.m. UTC
  • 93 keer bekeken
I have bought a KPN prepaid sim but I have not activated it in the Netherlands. I am now in Romania, and I really need the card activated. I have tried sending messages to activate it but it doesn't work. Can a moderator please activate it for me? I filled in all the needed information on my profile.
Good morning ​@Antoxchris, activating your sim from abroad is a bit difficult indeed!
Thank you for adding your information to your profile. I've activated the simcard for you. You should be able to use it in a bit, my advice would be to restart your mobile phone, then it should be all good!
2 reacties
  • jun 10, 2025 12:25 p.m. UTC
Good afternoon, thanks alot for solving the issue so quickly.
Best regards,
Antonio
