How can I activate prepaid outside the Netherlands
  • apr 8, 2025 8:49 a.m. UTC
  • 105 keer bekeken
How can i activate the SIM Card outside from the Netherlands?
Beste antwoord door RBxx
Hi ​@Donavan
You can only activate this yourself when you are in the Netherlands, connected to the KPN network.
However, a KPN employee can do this for you remotely.
Place your 06-number and SIM card number (ICCID) in your community profile . Use the field "Persoonlijke opmerkingen" and save your input by pressing "Sla wijzigingen op".
Report here when this is done, then I'll bring your question to the attention of the KPN moderators.
RBxx
  • apr 8, 2025 8:58 a.m. UTC
Hi ​@Donavan
  • apr 8, 2025 9:20 a.m. UTC
It’s done.
Thank you
  • apr 8, 2025 9:56 a.m. UTC
Hi ​@Donavan, welcome! I've activated the sim for you. It should work immediately. If not, restart your phone :)
Thanks, RBxx!
  • apr 8, 2025 10:13 a.m. UTC
Thanks for your Support!
Â
