Prepaidkaart vergeten te activeren in Nederland, hulp nodig voor gebruik in het buitenland
  • jan 14, 2026 4:11 p.m. UTC
  • 95 keer bekeken
I bought a prepaid card, but I forgot to activate it in the Netherlands. Now I urgently need to use the card abroad. Please help me activate it.I have filled in the relevant information in my profile.
Beste antwoord door Noordzee
Hallo ​@Guan K ,
Activeren vanuit het buitenland is helaas op geen enkele manier mogelijk. Je kunt de prepaidkaart pas activeren zodra je terugbent in Nederland.
Unfortunately, activating your card from abroad is not possible. You can only activate your prepaid card once you return to the Netherlands
bron:
  • jan 14, 2026 7:10 p.m. UTC
Hallo ​@Guan K ,
bron:
  • jan 15, 2026 3:53 a.m. UTC
I saw the previous discussion in the community that the webmaster can help activate it remotely.
  • jan 15, 2026 6:37 a.m. UTC
That was earlier. That’s not possible anymore.
  • jan 15, 2026 6:42 a.m. UTC
I have plugged in my mobile phone card abroad. I may not go back until a year later. Will my mobile phone card fail?
  • jan 15, 2026 7:23 a.m. UTC
Yes. The prepaid number will be gone. You can send your simcard to a friend in the Netherlands of you want to keep it. Then must that friend do the activation.Â
