Request to activate prepaid sim from abroad
  • September 28, 2025
  • 153 keer bekeken
Vasile Simon
Nieuwkomer
Hello,
I have a KPN prepaid SIM card that I need to activate. Unfortunately, I am currently outside the Netherlands and I cannot activate the SIM myself, because it only works in the KPN network.
Could you please help me activate my SIM card manually?
Thank you very much in advance for your help!
Admin edit:
Let op: je kunt jouw simkaart alleen activeren in Nederland. Ga je naar het buitenland? Zorg dan dat je jouw simkaart activeert vóór vertrek. Activeren vanuit het buitenland is niet meer mogelijk.
English: KPN Prepaid can only be activated in the Netherlands. So make sure to activate your simcard before going abroad.
Beste antwoord door RBxx
Hi ​@Vasile Simon
Please remove your private information (06 number and ICCID) from this message. Place it in your community profile, only visible for KPN. Use the field “Persoonlijke opmerkingen” and save your input by pressing “Sla wijzigingen op”.
In the mean time I will bring your request to the attention of the KPN moderators. They can help you with activating the prepaid SIM card.
2 reacties
RBxx
Hi ​@Vasile Simon
RBxx
Hi ​@Vasile Simon
Hi ​@Vasile Simon
I’ve just received a message from a moderator. Unfortunately they cannot do this anymore.
They now suggest you to contact KPN Webcare via Facebook  or X for help.
