Roaming service on Prepaid SIM
  • December 15, 2020
  • 282 keer bekeken
is it possible to activate roaming services on prepaid SIM ?  I would like to be able to received call while travelling abroad
Beste antwoord door Anonymous
For as far as I know is roaming adjustments needed for the use of data. Yes enough prepaid amount is needed. This page has a lot of info for you although it is in dutch.
https://www.kpn.com/prepaid/buitenland.htm
Make sure that you know the zones and Costs for example maritime and satelite also.
*Edit*
@Gohar
Be aware that your amount is usable abroad in zone 1 countries. Other zones are very expensive.
  • December 15, 2020
Roaming adjustments are abroad for calls not needed Your Phone works also on prepaid automatically.
  • December 15, 2020
Hi Friesian,
thanks for your feedback , so this means that I just need to top up my balance and my prepaid SIM will work automatically ?
  • December 15, 2020
*Edit*
@Gohar
