Slow internet Onbeperkt online
  • March 24, 2019
  • 257 keer bekeken
zaki27
Nieuwkomer
onbepertk online neit werk 128kb
4dagen stile slow i can't open web, and YouTube
and not calling.... cane someone help me😓
Admin: berichten samengevoegd en titel van je bericht aangepast
zaki27
Nieuwkomer
  • March 25, 2019
Forum|alt.badge.img+7
  • March 25, 2019
You can read your answer here: https://forum.kpn.com/prepaid-16/slow-internet-prepaid-467644
I advice you if you want to open web pages to download browser Opera Mini and to turn on the data savings settings.
zaki27
Nieuwkomer
  • March 25, 2019
thank you. #misja 20
i trayed. but not chenge
you thing my spdeed internet data 0.07mbps
  • March 25, 2019
Did you read what moderator wrote in the topic i linked?
The speed you are getting is like 70kbps while the max speed of this bundle is 128kbps, but knowing that apps on the background also use some data, what makes your speedtest a bit lower then it really is.
To keep it short, the speeds you are getting know is kinda normal to be honest.
Did you try using Opera Mini for browsing and also turned on the data save settings to extreme?
Becuase i use this bundle to and using Opera Mini to, and browsing works then much faster then if u use any other browser.
(U really have to download Opera Mini and not Opera Mobile, as they are different browsers)
Marcia van KPN
Hi @zaki27, welcome! It is exactly als Misja says: 70 kbps is the average speed you will get with the Onbeperkt Online. There's not much I can do about that unfortunately!
zaki27
Nieuwkomer
  • March 25, 2019
#marcia. thanks
iTs not problem i lose 10€ after that you Only save my credit. if not working internet. it's ok.
