Unlimited data bundle active even though I did not activate it
  • mrt 19, 2021 6:15 p.m. UTC
  • 51 keer bekeken
I bought the 1GB data bundle yesterday but I cannot use it because there is an Unlimited data bundle which is active. However, I never activated the Unlimited data bundle.
Now, I cannot use the 1GB data bundle - the speed is too slow.
  • mrt 20, 2021 6:49 a.m. UTC
@Marcia_ Hi, I have the same problem. Can you please help me to deactivate the Unlimited bundle so that I can use the 1GB bundle? Thanks
Admin: bericht naar eigen topic verplaatst
Lisa
Forum|alt.badge.img+17
  • Oud moderator
  • mrt 22, 2021 4:27 p.m. UTC
Hi @ruzaikr! It seems like you ordered the sim card with the unlimited bundle. I am not able to deactivate it. It has been active since June 2020. I need to ask a colleague if this is possible through a different department. If I receive an answer, I will of course let you know by writing a reply.
I'll hear from me!
Lisa
  • Oud moderator
  • mrt 31, 2021 2:06 p.m. UTC
In the meantime, you ordered a subscription. This also solved the issue. :sunglasses:
