How to determine if I have the right plug to attach a KPN modem?
  • 23 september 2020
  • 110 keer bekeken
Ramy_Kpn
Nieuwkomer
I want to purchase an internet connection package with KPN but I don’t know if I have the correct plug for it. Is this enough to attach a KPN router?
I checked by postcode and I can see that there is no optic fiber available, only normal internet connection.
Beste antwoord door TBloemink
It is indeed the one on the left, although it is the older version, it should still do the trick.
When you choose to join KPN for internet, the router will be delivered with the necessary plugs and cables, including this one.
2 reacties
  • 13289 reacties
  • 25 september 2020
The left outlet on the picture (4 holes) should do it.
TBloemink
Helper
Forum|alt.badge.img+3
  • 34 reacties
  • 25 september 2020
