How to activate HBOMax?
  • nov 15, 2022 10:16 a.m. UTC
  • 295 keer bekeken
Hi, I got the email to activate hbomax, but I click activate, it takes me to hbomax, then at the select provider I chose kpn, and I’m taken back to kpn offer page. it just goes on a loop. Also https://externediensten.kpn.com/Activeren page gives a 404
I was an hbo max user previously and switched to a subscription with kpn. i’m trying from my macbook
Beste antwoord door Anonymous
Yes it should, looks like you doing everything ok.
Then I don't know why it's not working for you.
You can call with customer service 0800-0402 (between 08:00 and 18:00), just tell to the computer you want to speak to an employee to get a real person on the phone.
Or fill in your forum profile, then a KPN employee/moderator can look at it, could take a couple of days before they get to this topic.
7 reacties
  • nov 15, 2022 4:02 p.m. UTC
Hello @astro
Did you do this from your internet connection at home, it only works from there.
Also it doesn’t work when you have a VPN connection active on your macbook.
To activate HBO Max you need a KPN ID and your “Thuis internet” subscription has to be added there, without doing that first you can't activate HBO Max.
Have you done that and logged on there first?
  • nov 15, 2022 8:48 p.m. UTC
Yes, I’m trying from the home wifi, there’s no VPN
Is “Thuis internet” the mobile app? where do I find the kpn id?
I was following these instructions https://www.kpn.com/televisie/pakketten/hbomax/activeren.htm
  • nov 15, 2022 8:50 p.m. UTC
I always get this error when clicking ”Activeren”
  • nov 15, 2022 8:52 p.m. UTC
You can login with your KPN ID here https://inloggen.kpn.com/ or make a new one if you haven't done that that yet on the same page.
That activation page works fine here, I get the same login page as in the link above.
  • nov 15, 2022 9:21 p.m. UTC
Yes, I’m already logged in to both kpn and the hbomax on the same browser. It should work, shouldn’t it? But the navigation flow directs me in a loop nothing is getting activated.
  • nov 15, 2022 9:36 p.m. UTC
  • nov 22, 2022 11:47 a.m. UTC
Hi, I got it resolved by creating a new hbomax account with the same email. Somehow it connected the subscription to kpn. Now it’s working fine.
