Experia V10a DHCP problemen
  • April 4, 2020
  • 182 keer bekeken
WouterKamphuis
Nieuwkomer
De laatste tijd hebben we vaak problemen met het internet. We hebben hier de Experia box V10a, die gaat er om de zoveel tijd uit. Hieronder de log van het moment dat die aangaat totdat die exit.
Apr  4 21:56:46 VRV9517 daemon.info dhcpd: DHCPDISCOVER from b0:eb:57:f5:f0:a8 (HUAWEI_MediaPad_M5-47422f) via br0
Apr  4 21:56:47 VRV9517 daemon.info dhcpd: DHCPOFFER on 192.168.2.2 to b0:eb:57:f5:f0:a8 (HUAWEI_MediaPad_M5-47422f) via br0
Apr  4 21:56:48 VRV9517 daemon.info dhcpd: Reclaiming not used lease 192.168.2.2.
Apr  4 21:56:48 VRV9517 daemon.info dhcpd: DHCPREQUEST for 192.168.2.2 (192.168.2.254) from b0:eb:57:f5:f0:a8 (HUAWEI_MediaPad_M5-47422f) via br0
Apr  4 21:56:48 VRV9517 daemon.info dhcpd: DHCPACK on 192.168.2.2 to b0:eb:57:f5:f0:a8 (HUAWEI_MediaPad_M5-47422f) via br0
Apr  4 21:57:14 VRV9517 daemon.notice pppd[11031]: pppd 2.4.1 started by root, uid 0
Apr  4 21:57:15 VRV9517 daemon.notice pppd[11085]: pppd 2.4.1 started by root, uid 0
Apr  4 21:57:16 VRV9517 daemon.info dhclient: adapter index 34
Apr  4 21:57:16 VRV9517 daemon.info dhclient: DHCPDISCOVER on ptm0.4 to 255.255.255.255 port 67 interval 3
Apr  4 19:57:18 VRV9517 daemon.notice miniupnpd[5329]: shutting down MiniUPnPd
Apr  4 21:57:18 VRV9517 user.info miniupnpd: Upnp Ignore Mode
Apr  4 21:57:18 VRV9517 daemon.notice miniupnpd[11387]: HTTP listening on port 55150
Apr  4 21:57:18 VRV9517 daemon.warn miniupnpd[11387]: no HTTP IPv6 address, disabling IPv6
Apr  4 21:57:19 VRV9517 daemon.info dnsmasq[6086]: exiting on receipt of SIGTERM
Apr  4 21:57:19 VRV9517 daemon.info dhclient: DHCPDISCOVER on ptm0.4 to 255.255.255.255 port 67 interval 7
Apr  4 21:57:19 VRV9517 daemon.info dhclient: adapter index 34
Apr  4 21:57:19 VRV9517 daemon.info dhclient: DHCPOFFER from ptm0.4:10.29.168.1
Apr  4 21:57:19 VRV9517 daemon.info dhclient: DHCPREQUEST on ptm0.4 to 255.255.255.255 port 67
Apr  4 21:57:20 VRV9517 daemon.info dhclient: DHCPACK from 10.29.168.1
Apr  4 21:57:21 VRV9517 daemon.info dnsmasq[11459]: make: family 2
Apr  4 21:57:21 VRV9517 daemon.info dnsmasq[11459]: make: family 10
Apr  4 21:57:21 VRV9517 daemon.info dnsmasq[11462]: started, cache disabled
Apr  4 21:57:21 VRV9517 daemon.info dnsmasq[11462]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-DNSSEC no-ID loop-detect inotify
Apr  4 21:57:21 VRV9517 daemon.info dnsmasq[11462]: read /etc/hosts - 6 addresses
Apr  4 21:57:21 VRV9517 daemon.info dnsmasq[11462]: using nameserver 195.121.1.34#53
Apr  4 21:57:21 VRV9517 daemon.info dnsmasq[11462]: using nameserver 195.121.1.66#53
Apr  4 21:57:21 VRV9517 daemon.info dhcpd: Wrote 5 leases to leases file.
Apr  4 21:57:23 VRV9517 daemon.info dhclient: bound to 10.29.169.208 -- renewal in 1797 seconds.
Apr  4 21:57:24 VRV9517 daemon.info dnsmasq[11462]: exiting on receipt of SIGTERM
Apr  4 21:57:26 VRV9517 daemon.info dnsmasq[11716]: make: family 2
Apr  4 21:57:26 VRV9517 daemon.info dnsmasq[11716]: make: family 10
Apr  4 21:57:26 VRV9517 daemon.info dnsmasq[11718]: started, cache disabled
Apr  4 21:57:26 VRV9517 daemon.info dnsmasq[11718]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-DNSSEC no-ID loop-detect inotify
Apr  4 21:57:26 VRV9517 daemon.info dnsmasq[11718]: read /etc/hosts - 6 addresses
Apr  4 21:57:26 VRV9517 daemon.info dnsmasq[11718]: using nameserver 195.121.1.34#53
Apr  4 21:57:26 VRV9517 daemon.info dnsmasq[11718]: using nameserver 195.121.1.66#53
Apr  4 21:57:26 VRV9517 daemon.info dhcpd: Wrote 5 leases to leases file.
Apr  4 21:57:29 VRV9517 daemon.info dnsmasq[11718]: exiting on receipt of SIGTERM
Apr  4 21:57:31 VRV9517 daemon.info dnsmasq[12000]: make: family 2
Apr  4 21:57:31 VRV9517 daemon.info dnsmasq[12000]: make: family 10
Apr  4 21:57:31 VRV9517 daemon.info dnsmasq[12002]: started, cache disabled
Apr  4 21:57:31 VRV9517 daemon.info dnsmasq[12002]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-DNSSEC no-ID loop-detect inotify
Apr  4 21:57:31 VRV9517 daemon.info dnsmasq[12002]: read /etc/hosts - 6 addresses
Apr  4 21:57:31 VRV9517 daemon.info dnsmasq[12002]: using nameserver 195.121.1.34#53
Apr  4 21:57:31 VRV9517 daemon.info dnsmasq[12002]: using nameserver 195.121.1.66#53
Apr  4 21:57:31 VRV9517 daemon.info dhcpd: Wrote 5 leases to leases file.
Apr  4 21:58:01 VRV9517 user.info arc_link_state: WAN Link Down
Apr  4 21:58:01 VRV9517 daemon.err dhclient: /etc/dhcpc-wan2.leases line 4: lease specified for unknown pseudo.
Apr  4 21:58:01 VRV9517 daemon.err dhclient:   server-address 0.
Apr  4 21:58:01 VRV9517 daemon.err dhclient:                   ^
Apr  4 21:58:01 VRV9517 daemon.err dhclient: /etc/dhcpc-wan2.leases line 4: expecting semicolon.
Apr  4 21:58:01 VRV9517 daemon.info dhclient: DHCPRELEASE on ptm0.4 to 10.29.168.1 port 67
Apr  4 21:58:03 VRV9517 user.info arc_link_state: WAN Link Down Stage2
Apr  4 21:58:03 VRV9517 daemon.info pppd[11031]: Exit.
Apr  4 21:58:04 VRV9517 daemon.info pppd[11085]: Exit.
Het lijkt erop alsof die problemen heeft met de DHCP lease zetten. Enig idee hoe dit probleem is op te lossen?
Hoi @WouterKamphuis, welkom hier.
Het modem valt dus om de zoveel tijd uit. Ik zie het inderdaad. Wat heb je hier al aan gedaan? Heb je het modem al een reset gegeven? Ook wil ik graag nog eens meekijken naar jouw verbinding. Zou je daarvoor jouw Forumprofiel willen voorzien van postcode + huisnummer en naam van de contractant? Ik hoor graag als je dat gedaan hebt, dan kijk ik mee.
2 reacties
Bart van KPN
  • April 7, 2020
Bart van KPN
Ik heb geen reactie meer ontvangen, ik ga er daarom vanuit dat het opgelost is. Zo niet, hoor ik graag van je.
