How do I set up a TP-Link Archer AX11000?
  • nov. 13, 2023 5:02 p.m. UTC
  • 204 keer bekeken
Alex Flav
Deelnemer
Hi all,
It might be off topic but I just want to replace the Sagem modem CS 50001 rom KPN with my home router Archer AX11000. Can you please share the setup details? ThanksĀ
Beste antwoord door XS4-Arjan
HiĀ @Alex Flav , welcome to KPN Forum, where customers help each other.
KPN has some help pages for you (in Dutch) in case you do not want to use standard KPN equipment:
Ā
Ā
Ā
Ā
XS4-Arjan
  • nov. 15, 2023 12:11 p.m. UTC
Ā
Ā
Ā
Ā
Alex Flav
Deelnemer
  • nov. 16, 2023 7:24 p.m. UTC
Thanks for your reply, I read almost all recently posted pages from this topic without finding the best answer. I just wanted to know the basics setup for Internet connectionĀ  such as connection type, username and password, port forwarding, IP type v4 or v6...and so one. Thanks again for your help! B
Best regards!
Alex Flav
Deelnemer
  • nov. 18, 2023 6:49 p.m. UTC
Hi all,
Thanks for your help!
Today I managed to configure my router to the KPN FO network with assistance of Service Plus engineers.
The settings are following: Internet connection type: PPPoE, user:internet password: internet. Advanced tab to IPTV/VLAN as below:
Thank you and good luck!
Ā
