Instellen Eigen router (Fortigate 60F) Met IPTV, Options
  • May 28, 2020
  • 76 reacties
  • 10274 keer bekeken
76 reacties
  • January 15, 2023
bij deze @wjjkpn
wel zelf natuurlijk een ipv6 route instellen , ipv6 policies maken.
config system interface
    edit "wan"
        set vdom "root"
        set allowaccess ping
        set type physical
        set monitor-bandwidth enable
        set role wan
        set snmp-index 1
        set dns-server-override disable
        set mtu-override enable
        set mtu 1514
    next
end
De vlan6 sub interface :
    edit "internet"
        set vdom "root"
        set alias "vlan6"
        set estimated-upstream-bandwidth 1024000
        set estimated-downstream-bandwidth 1024000
        set role wan
        set snmp-index 14
        config ipv6
          set ip6-allowaccess ping
          set dhcp6-prefix-delegation enable
          set ip6-send-adv enable
          set ip6-manage-flag enable
          set ip6-other-flag enable
          config dhcp6-iapd-list
            edit 1
            next
          end
      end
        set mtu 1506
        set interface "wan"
        set vlanid 6
    next
dan de pppoe sub sub interface:
edit "pppoe"
        set vdom "root"
        set mode pppoe
        set type tunnel
        set role wan
        set snmp-index 15
        config ipv6
            set ip6-mode dhcp
                edit 1
                next
            end
        end
        set interface "internet"
    next
en de pppoe settings:
config system pppoe-interface
    edit "pppoe"
        set ipv6 enable
        set device "internet"
        set username “blabla@internet"
        set password ENC xxxx.
    next
end
En de LAN kant:
    edit "lan"
        set vdom "root"
        set ip 10.0.0.1 255.255.255.0
        set allowaccess ping https ssh snmp fgfm fabric
        set type hard-switch
        set stp enable
        set device-identification enable
        set role lan
        set snmp-index 5
        config ipv6
            set ip6-mode delegated
            set ip6-upstream-interface "pppoe"
            set ip6-delegated-prefix-iaid 1
            set ip6-subnet ::1/64
            config ip6-delegated-prefix-list
                edit 1
                    set upstream-interface "pppoe"
                    set delegated-prefix-iaid 1
                    set subnet ::/64
                    set rdnss-service delegated
                next
            end
                edit 19
                next
            end
        end
    next
end
en de dhcp6 server:
config system dhcp6 server
    edit 1
        set rapid-commit enable
        set subnet ::/64
        set interface "lan"
        set ip-mode delegated
        set dns-server1 2620:fe::fe
    next
end
Thanks! Ik ga eens knutselen hiermee.
