Is it possible to use my own Modem that has a built-in VPN?
  • April 25, 2023
  • 159 keer bekeken
Martin Hymers
Nieuwkomer
I want to use Fibreoptic Internet with my VPN on my current modem. Is this possible as I understand the KPN Modem cannot be put into Bridge Mode?
Beste antwoord door Vulpen
Hi Martin welcome to the KPN Forum,
No the Modem/Routers of KPN do not have an VPN client/server build in. But its possible to host an VPN server or use a VPN client on a device on your home network. For a Server you probably need to open some ports on your modem to make it reachable from the internet side.
  • April 25, 2023
If you don't have television from KPN this should not be a problem. The only thing is that your router needs to setup a pppoe connection on vlan 6.
Martin Hymers
Nieuwkomer
  • April 26, 2023
Does the KPN Modem have a built in VPN?
If not, can a VPN be used in my home network?
Admin: merged topics
Vulpen
  • KPN Medewerker
  • April 26, 2023
