Wiz Smart Plug: It does not work with my WiFi from Box 12
  • January 7, 2023
  • 8 reacties
  • 173 keer bekeken
Emmanuella Nodari
Deelnemer
Hello!
I recently bought a smart plug (brand Wiz) that operates on 2.4GHz Wifi, however it does not work when I’m using my wifi. I tried to use the “guest” wifi, but it doesn’t work. I tried to use the extra wifi with only 2.4 GHz, but it doesn't work either. When I tried to use the smart plug with a phone’s hotspot, it worked out perfectly, but of course I cannot use it every time with a hotspot. I looked out here in the forum to see if I needed to “turn off” a firewall, but I saw that Box 12 (the one that I have) does not have that option.
Anyone can help me figure out this problem?
Thank you so much in advance
Beste antwoord door Anonymous
@Emmanuella Nodari
During setup of the Plug your phone has to be connected to the same (extra WiFi) network, I presume you are doing that?
Or else you could try this, found this on there website, how this actually is connecting a Plug to the network is unclear to me:
8 reacties
  • January 7, 2023
Hallo @Emmanuella Nodari
You can try if setting the Box 12 to WiFi 5 for 2.4GHz will help.
Go to WiFi Settings, change the Wireless Mode to 802.11b+g+n (2.4GHz), this will also have effect on the Extra WiFi network.
Emmanuella Nodari
Deelnemer
@GeSp Thank you for your reply!
However I already have the settings on that mode and still it does not work.
Do you have any other advice?
  • January 7, 2023
@Emmanuella Nodari
Yes, that's the default (WiFi 6), you should change that to 802.11b+g+n (WiFi5) some equipment doesn't work with WiFi 6
Emmanuella Nodari
Deelnemer
@GeSp Do I need to change both to 802.11b+g+n? Cause right now I changed only one of them and it stil does not work :(
  • January 7, 2023
If the SmartPlug only uses 2.4GHz you don’t have to change the 5GHz setting.
You can try it but if don't think it will make any difference, WiFi 5 for 5GHz is  802.11a+n+ac
Did you also try to connect it to the Extra WiFi network after changing the 2.4GHz setting?
Emmanuella Nodari
Deelnemer
@GeSp Thank you so much for all of your advices.
Yes, I tried to connect the extra wifi network after changing the settings, but still it does not work, it says on the Wiz app that I have a problem with a “transmission of UDP on my network”, do you know what I could do?
  • January 7, 2023
@Emmanuella Nodari
Emmanuella Nodari
Deelnemer
@GeSp Thank you so much! It worked!
