Antwoord
Unlock iPhone 7 plus
  • October 23, 2019
  • 1 reactie
  • 150 keer bekeken
Dear Sir/ Madam,
I would like to unlock my iPhone 7 Plus as I want to use another SIM card! Please consider that I’m abroad currently and this is urgent.
Please send me the instruction to my email *
best regards,
parizad
*Admin: e-mailadres verwijderd i.v.m. privacy.
Beste antwoord door Susan_
Goodmorning @Parizad saremi, welcome on our Forum and thanks for your question.
If you still have a simlock on your device, you can request an unlock code via our website. You need your IMEI-number (the IMEI number is the serial number of your device. You can request the IMEI number by entering the code * # 06 # on your device, after which the IMEI number appears on your display). The application for an unlock code is free. You will receive the unlock code by e-mail within 4 weeks.
But nowadays, most devices no longer have a simlock. Are you sure it's a simlock?
1 reactie
Susan_
  • October 28, 2019
