Landline doesn't work sometimes, without a pattern
  • aug 30, 2024 12:48 p.m. UTC
  • 1 reactie
  • 41 keer bekeken
This is a problem with my landline which comes and goes without a pattern. My line has no dial tone and I cannot make any calls. I cannot receive calls either as it appears busy. Call forwarding works when set to 0 rings. The online tool can find no problem with the network in the area or the settings. I have tried the following:
Restart modem or telephone
Change cable
When disconnecting my telephone device completely line still apperas busy when I call
The problem persists for hours and maybe suddenly resolved by itself and come back later or another day.
Thank you in advance for your help
Beste antwoord door PeterG
Welcome to the kpn community 🙂
Then it looks like a problem with the SIP server, which transfers VoIP to PSTN, in the modem.
Which type of modem do you have of kpn?
1 reactie
  • aug 30, 2024 12:57 p.m. UTC
