Can I Remove the foot off the SuperWifi disc so I can hang it against the wall?
  • December 9, 2021
  • 1 reactie
  • 112 keer bekeken
How do I remove the foot off the super wifi disc so that I can hang it against the wall?
Beste antwoord door RBxx
Hi @derie003
As you own the SuperWiFi you may open the unit by splitting the shell. Be careful, it's at your own risk! Inside you'll find the screw that holds the foot. See the following topic:
Be aware that the cables at the back will prevent you from placing the unit close to the wall as well.
1 reactie
RBxx
  • December 9, 2021
Hi @derie003
