Purple light on wifi booster
  • July 5, 2023
  • 456 keer bekeken
All reset options do not fix the problem
@Karen 2 Welcome to our forum.
Have you already tried to do a clean installation of the Superwifi boosters?
If that doesn't work, could you let us know?
7 reacties
Cappuccino2
Helper
What kind of wifi boosters are you using and what kind of modem?
  • July 5, 2023
Super wifi 2.0 and modem supplied by KPN in September 2022 (can’t see model)
  • July 5, 2023
Purple means it does not know what to do. You will need to reconnect it with a wire to the modem for 15 to 30 minutes and after that you can place it back where it came from wireless
  • July 5, 2023
Thanks - tried that but back to purple again …..
Cappuccino2
Helper
Take a picture of the modem so we can at least see what you are using.
Also when u connect the wifi booster with an Ethernet cable to the modem for like 15 to 25 minutes like ik_combineer sugested does the led light stay green after that while the Ethernet cable is still connected ?
  • July 5, 2023
It goes green for a little while, then flashes green a few times and then goes back to purple.
Rutger van KPN
  • July 9, 2023
If that doesn't work, could you let us know?Â
