SuperWifi 2 point will not work wirelessly
  • July 5, 2026
  • 102 keer bekeken
Hi all,
I became a KPN customer recently and I am honestly stunned by the experience so far. Apparently KPN sends WiFi modems and WiFi extension devices, but it does not promise that they will work.
My situation:
• Modem: KPN Box 12b
• One SuperWifi 2 point (black)
• The SuperWifi point works perfectly while connected to the modem with an ethernet cable: solid green, stable, for 45+ minutes
• The second I remove the cable, it turns red and never recovers. This happens even when the point is standing right next to the modem, so distance is not the issue
What I have already done:
• Followed the official installation instructions exactly, multiple times
• Factory reset the SuperWifi point more than 10 times (reset pin until red blinking, waited for purple)
• Full factory reset of the modem itself, then reconnected the point by cable, waited 30+ minutes for solid green, then disconnected next to the modem. Still red
• Power-cycled the point after disconnecting. Still red
• Went to a KPN store and swapped the SuperWifi point for a brand new one. Identical failure
• The modem was changed from v10 to 12b. Same result
Two different extenders failing in exactly the same way means the problem is not the extender. Everything points to the Box 12b, and I have seen reports on this forum of the same symptoms being resolved only by replacing the Box 12b.
I have spent hours on the phone with customer service across multiple calls. The last agent told me, literally, that everything has been done, nothing else is possible, I cannot cancel my contract, and I should just keep the extender permanently cabled to the modem. That is not a solution. A wireless extender that only works with a cable, placed next to the modem, is a product that does not do the one thing it exists for.
What I am asking for: a monteur appointment or a replacement of the Box 12b. I am happy to provide any diagnostics needed.
Can a moderator please pick this up? I would like to resolve this properly before considering the formal complaint route.
Thanks in advance.
Hi ​@the428, welcome to our community, I'm not sure what's going on here. Did you have the same issue with the V10 before your Box12?
What software version do your devices have? Specifically the SuperWifi points? Did you purchase these with us or elsewhere?
If you'd like to schedule a technician you can do so on kpn.com/monteur but my colleagues on the phone should also be able to help you with this, the same for exchanging the box12
Edit: we're improving some things with the latest updates:
Product Updates | KPN Community
2 reacties
Thomas van KPN
Forum|alt.badge.img+5
  • July 8, 2026
Ik weet niet maar het is normaal dat als het wifi punt na het los koppelen en ergens draadloos komt te staan , dat sw2 punt een minuut of 1 a 2 rode led geeft, dan gaat sw2 punt groen en rood knipperen om vervolgens op groen te blijven.
Soms knippert sw2 punt ook even Blauw, sm dan is die met modem of ander sw2 punt aan het communiceren.
Sorry zet vertaling maar aan, vond uitleg zo in het Nederlands het makkelijkst
