SuperWifi can't connect to modem, led remains purple
  • jul. 12, 2026 12:04 p.m. UTC
  • 79 keer bekeken
HI
I’m trying to connect Super Wifi 2 to KPN box. I followed the instruction mentioned in the booklet and also  online installation guide. However the Super Wifi-2 is not working. It remains in purple color.
When I connect Super Wifi 2 to KPN Box via ethernet cable then it is turn green and remain green.
I’ve also tried to reset it multiple times and each time after reset I left the Wifi connected to Box more that 30 mins. Every time when it is connected via ethernet cable it remain green.
However when I remove ethernet cable and restart the light remain purple.
I’ve also tried WPS switch option. Still no luck.
Please advice.
Kind regards,
Pradeep
  • jul. 14, 2026 10:29 a.m. UTC
Hi ​@praks411 . Welcome to the KPN Community.
Thank you for your message. I'm sorry to hear you're having trouble connecting your SuperWifi 2.
Based on your description, it seems that the SuperWifi 2 works correctly when connected to your KPN Box with an Ethernet cable, but it does not establish a wireless connection after the cable is removed.
Could you please let us know which KPN modem you are using? We would also like to know whether the SuperWifi 2 units are brand new or have been used before. If possible, could you also tell us the firmware version of your modem?
  • jul. 19, 2026 10:00 a.m. UTC
HI
Thanks for your reply.
I’m using KPN Box 12 with SuperWifi-2. The SuperWifi is new it is not used before. I’m trying to use it for first time. However it is not connecting. The ethernet cable connection is working fine the light is green. But when I remove the cable then it doesn’t connect and light remain purple.  I tried multiple times reset the box, using WSA, multiple power cycles, none of them helped. Here are the details for KPN box and SuperWifi-2
Kind regards,
Pradeep
Forum|alt.badge.img+5
  • jul. 20, 2026 5:56 a.m. UTC
Your sw2 point has the original/ old software, that is the reason.
  • jul. 26, 2026 9:25 a.m. UTC
What are my options here? Shall I return the device or is there still something I can do?
I’ve also noticed that when I login to SuperWifi2 and change the default password then led turns red
when cable is not connected instead of purple when I keep the default password.,
When the cable is connected then leds eventually turns green everytime and remain green.
