SuperWifi punt light is flashing purple
  • October 27, 2025
  • 138 keer bekeken
Hello, I hope it's ok to ask in English as Dutch is not yet good enough.
We have a Super Wifi. Since yesterday the purple light is flashing. I have clicked the buttons on the device to reset but it doesn't do anything. I kept it off overnight but issue is not fixed.
Looking at the question library it says it's connected to non-KPN network which I don't know how is possible since we only have ONE network and it is KPN. I also see advise to reconnect with KPN network but no link or explanation how to do it.. It would be great to have a bit of detailed help.
Many thanks
Hi ​@JurgitaVD, welcome to our community. Is your internet also not working? The purple light indicates something went wrong with the migration to the new software. To fix this you should connect it to the modem with a cable and keep it there for about half an hour so it can update.
Dit betekent dat het SuperWifi punt niet geconfigureerd is.
Sluit hem rechtstreek bekabeld aan op je modem, zonder andere apparatuur ertussen (switch, draadloze verbindingsset, etc.) Na enkele minuten is de configuratie ingeladen en zal het SuperWifi punt weer groen branden.
Als dit niet zo is, volg dan de stappen voor een rood of groen knipperend lampje hierboven.
Wil je meer weten over SuperWifi punten installeren en gebruiken? Lees dan hier verder:
Thomas van KPN
  • October 29, 2025
  • October 30, 2025
Thank you, connecting with a cable worked
Thomas van KPN
great! Thanks for the reply!
