Factuur twee keer afgeschreven
  • jun. 3, 2022 7:33 a.m. UTC
  • 85 keer bekeken
Good morning, I paid for the invoice on May 19.  And now I see that you have charged the invoice for the second time on 02-06-2022.  I would like to clarify this
Hello @Sebastian 1984. Generally we do not charge the same invoice twice. It could be that you have paid an invoice yourself and that we followed with a direct debit. In which case you'll automatically get back your money within 2 weeks.
Sometimes, however, the payments are not for the same invoice. Even though it looks like it. If you want to know for certain, you can always give us a call at 0800 0402. Our department Collections can look into it for you.
  • jun. 3, 2022 6:13 p.m. UTC
Eerste factuur en een tweede factuur?
Denise van KPN
  • jun. 6, 2022 2:02 p.m. UTC
  • jun. 6, 2022 3:21 p.m. UTC
Ik denk dat het gewoon 2 verschillende factoren zijn, en dat het probleem al lang opgelost is.
