My first invoice is higher than I expected
  • March 2, 2023
  • 73 keer bekeken
Hi, I got the first invoice and I was charged much more than I expected. I think it is because there are two periods. What I am wondering is why I get charged for the period 22.02-21.03 which I haven't even used yet already.
Beste antwoord door huistijger
Hey @Claudiaaa
With KPN you pay 1 month in advance, which is why your first bill is higher than the rest of the year.
2 reacties
huistijger
  • March 2, 2023
Hey @Claudiaaa
Bram van KPN
Forum|alt.badge.img+17
  • March 4, 2023
Hi @Claudiaaa! What @huistijger said here is correct.
What is important is to check the dates on the first invoice. You will see per day what you've paid. Also check the confirmation e-mail you got. It should say exactly what your normal monthly amount is.
You will find the specification of your invoice in your MijnKPN
