Can't find ISRA - but I have a POA 01-UPC (Coax)
  • December 1, 2022
  • 411 keer bekeken
Hi everyone!
I have a problem in finding ISRA and all the other connection points suggested by KPN.
However, I do have something called POA 01-UPC (see picture below).
Is there anything I can do with this?
Thank you so much for your help!
Beste antwoord door Anonymous
Hello @Virginiastecchini
Unfortunately that connection is only for cable internet, KPN can't provide internet over a cable connection.
If you can order KPN internet then there should be a connection point somewhere in your house, most common places are in the livingroom or in the metercupboard.
You can't find any of these?:
  • December 1, 2022
Thank you @GeSp for your response!
However, I looked everywhere and it seems impossible to find something similar.
I wonder if I can buy an adapter? From Coax to ethernet, so something like this:
Thank you!
MR_CHIP
Forum|alt.badge.img+7
  • December 1, 2022
no ziggo uses coax signal
kpn uses ISRA copper/Fiber
