Cannot connect to internet using KPN Isra box
  • March 4, 2023
  • 12 reacties
  • 99 keer bekeken
cannot connect using kpn isra box. nobody actually help in kpn. disgusting customer care.
I recently moved into an apartment. kpn moved my internet also. but i cannot connect using the ISRA telephone box available at house.
12 reacties
  • March 4, 2023
Rutger van KPN
@sirajwebs Welcome to our forum.
Sorry to read that you are not able to connect your modem.
I can understand that it doesn't work out looking at the ISRA point.
Could you fill in your forum profile and let me know when you did?
Then I can check what I can do for you!
DLD
  • March 4, 2023
Try using the white and copper wires.
  • March 4, 2023
i already tried that.
  • March 4, 2023
i have filled the profile data @Rutger_
  • March 4, 2023
i tried all combination black-transparent, white-transparent, red-red, blue-blue, green-green, yellow-yellow, red-blue, blue-red….
nothing works
Forum|alt.badge.img+27
The best thing right now is to order an engineer to fix this issue. The next one available is on Tuesday, the 7th of March between 8 en 10 in the morning. I have scheduled the engineer on that day and time. Does this suit you?
  • March 4, 2023
how much does this cost me ? because KPN says if the connection is not ready yet, then mechanic will come and fix it for free.
In this case nothing, because your ISRA point does not work.
  • March 4, 2023
Thanks
You’re very welcome.
  • March 7, 2023
mechanic came today and fixed the line. there was no connection made earlier. so he gave a connection from outside building with a new box. finally after 2 weeks of struggle it's fixed. Thanks.
