Experia Box v10a shows red light after unplugging
  • October 16, 2021
  • 159 keer bekeken
TanjaLuebbers
Nieuwkomer
Hey,
The household I am living in is using the Experia Box v10a, I unplugged the box to connect it to a longer cable. This however did not seem to work as it kept on showing a red light. Even resetting had no affect. So I plugged the Box back into the original cable which now shows the same issues with a red light. Initially on a difference place that indicates a WiFi sign a blue light is blinking, this eventually turns off, but the main light continues to be red. Also after resetting or unplugging. What a can I do? Basically nothing has changed but the box has stopped working.
Beste antwoord door Anonymous
Hello @TanjaLuebbers
Did you reconnect all cables in the same modem ports and made sure they are plugged in properly?
Do you have a copper of glasfiber connection?
Copper is connected via a smaller RJ11 connector in the DSL port of the Experiabox and glasfiber is connected with a wider RJ45 connector in the WAN port of the Experiabox.
2 reacties
  • October 17, 2021
Thomas van KPN
Hi @TanjaLuebbers, welcome on our forum!
The red light is an indication that your V10a is not connecting to the internet. As @GeSp suggests this is usually an issue with the cable.
Could you elaborate on how the cables are connected? If you have a fiber connection what the LED's on the fiber unit are indicating?
