Fiber unit glass light not green
  • jan 12, 2024 7:23 p.m. UTC
  • 93 keer bekeken
Well you installed it correctly so if the connection light isn't on then the connection outside is probably wrong. The only solution is an engineer. Call KPN at 0800-0402 (24/7) and say your services aren't working and you need an engineer.
2 reacties
  • jan 12, 2024 7:26 p.m. UTC
  • jan 12, 2024 7:27 p.m. UTC
Thank you for your help much appreciated 🙏
