Hallo klantenservice,
Als oplossing voor een probleem met Ziggo heb ik de splitter van het AOP vervangen (zonder resultaat).
Helaas is tijdens het vervangen van de splitter om onduidelijke reden ook de KPN modem ermee gestopt.
Ik heb dus nu helemaal geen internet meer en heb deze reactie geplaatst via het internet bij mijn dochter.
KPN modem log info or higher na restart in GUI (Date/Time Severity Module Message):
01.01.2020 01:01:41 Info SYS Modem login was successful
01.01.2020 01:01:02 Info WIFI A WiFi device has successfully connected to SSID (Device/WiFi/SSIDs/SSIDsWL_PRIV])
01.01.2020 01:00:50 Info WIFI Channel: (36/100) Channel Hopping initiated/Manually initiated
01.01.2020 01:00:46 Info WIFI A WiFi device has successfully connected to SSID (Device/WiFi/SSIDs/SSIDsWL_PRIV])
01.01.2020 01:00:46 Info WIFI Device was disconnected on SSID (Device/WiFi/SSIDs/SSIDsWL_PRIV])
01.01.2020 01:00:43 Info WIFI Channel: (11/6) Channel Hopping initiated/Manually initiated
01.01.2020 01:00:37 Info WIFI A WiFi device has successfully connected to SSID (Device/WiFi/SSIDs/SSIDsWL_PRIV])
01.01.2020 01:00:26 Info UPNP UPnP functionality has been activated
01.01.2020 01:00:19 Info DHCPS The LAN DHCP Server is active
01.01.2020 01:00:19 Info WIFI WLAN has been activated (u4lKVT5j6YgMZqWFqejb) (band : 5GHz).
01.01.2020 01:00:19 Info WIFI WLAN has been activated (u4lKVT5j6YgMZqWFqejb) (band : 2.4GHz).
01.01.2020 01:00:19 Info WIFI WLAN has been deactivated (wifi-ap2_ExtraWiFi5G) (band : 5GHz).
01.01.2020 01:00:19 Info WIFI WLAN has been deactivated (wifi-ap2_ExtraWiFi2G) (band : 2.4GHz).
01.01.2020 01:00:19 Info WIFI WLAN has been activated (KPN2A6DA6_guest) (band : 5GHz).
01.01.2020 01:00:19 Info WIFI WLAN has been activated (KPN2A6DA6_guest) (band : 2.4GHz).
01.01.2020 01:00:19 Info WIFI WLAN has been activated (wifi-ap2) (band : 5GHz).
01.01.2020 01:00:19 Info WIFI WLAN has been activated (wifi-ap2) (band : 2.4GHz).
01.01.2020 01:00:18 Info WIFI Channel: (0/36) Channel Hopping initiated/Manually initiated
01.01.2020 01:00:18 Info WIFI Channel: (0/11) Channel Hopping initiated/Manually initiated
01.01.2020 01:00:16 Info SYS OWL connection status changed from absence of Mesh devices to absence of Mesh devices
01.01.2020 01:00:15 Info SYS The Modem has successfully powered up
01.01.2020 01:00:15 Info SYS The Modem underwent a warm reset
01.01.2020 01:06:58 Info SYS A device reset was performed (GUI/Button)
01.01.2020 01:06:57 Info SYS A device reset was performed (GUI/Button)
01.01.2020 01:03:59 Info SYS Modem login was successful
