How do I return my modem when emigrating?
  • September 14, 2021
  • 172 keer bekeken
Hi. I’m leaving the country next month, going back to my homeland. I see that I have to provide a proof of gemeente deregistration. But, if I wat until I have the proof, then it will be too late to send the internet box as I will be already abroad, And I can’t send the internet box and cancel the contract before leaving because you ask for thar proob.
How can I manage this?
Hi @FrancescBox, welcome to our forum!
The easiest way would be to just return it in a box with your customer number or adress on it.
You can use our free return-adress:
KPN
Antwoordnummer 10119
2400 VB Alphen aan den Rijn
7 reacties
Thomas van KPN
  • September 15, 2021
KPN
Thanks @Thomas , can I return it before getting all the papers required, like the gemeente exit ones? Because, as I said, by the time I get them I will be already abroad.
Thomas van KPN
Yes no problem, you can return them whenever you want really!
  • October 25, 2021
I canceled my account, and did not get yet the folded box to send the modem back to KPN. Who should I contact ?
  • October 25, 2021
Hello @Adva  see this website from KPN:
https://www.kpn.com/service/administratie/terugsturen.htm#/ser-terugsturen/ser-terugsturen-huur-bruikleen-opzeggen-annuleren
You can use your any empty box you can get, from the supermarket, by example.
Good luck.
  • October 25, 2021
  • October 25, 2021
@Adva
When using a box of your own don't forget to insert a note with your customernumber (klantnummer) and name and address.
