How to cancel my subscription?
  • 5 oktober 2021
  • 227 keer bekeken
Hello.
I have a contract with one month period of notice. At the end of the year I am going to move out of the place where I have a network connection. What should I do to toresign the contract and what should I do with the modem and 4G Buitengebuid device?
*Admin: titel aangepast voor een betere vindbaarheid
Beste antwoord door Anonymous
Hello @pitig91
You can find here how to cancel your contract (in Dutch): https://www.kpn.com/service/administratie/opzeggen/internet-en-tv/verhuizen-samenwonen-emigreren.htm
Easiest is to call with 0800-0402
The modem and 4G device you must return to KPN, normally the will sent you a box to return the equipment in. See also (in Dutch): https://www.kpn.com/service/administratie/terugsturen.htm#/ser-terugsturen/ser-terugsturen-huur-bruikleen-opzeggen-annuleren
If you haven't received that box in time you can sent it in any box to:
Kpn
Antwoordnummer 10119
2400VB Alphen aan den Rijn
Make sure you receive a ticket from the postoffice that you sent the box with the equipment and keep that ticket so you can later prove (if necessary) that you send it back.
  • 0 reacties
  • 6 oktober 2021
Hello @pitig91
Kpn
Hi @pitig91, I see GeSp has provided you with the different options to cancel your subscription. Have you been able to use one of those suggestions? If not, you can still do that.
  • 9 reacties
  • 7 oktober 2021
I didn't try it because I will be moving out in the end of December so I still need network connection. Is it ok if I do it one month earlier?
  • 0 reacties
  • 7 oktober 2021
Hello @pitig91
Yes, that is ok.
You should cancel it at least 1 month in advance because the notice period is 1 month.
