I only get 200-300 Mb/s on my 1Gbit/s connection
  • July 31, 2023
  • 107 keer bekeken
I hired a 1 Gbps connection and it never EVER remotely reached this speed.
Usually I got 200 to 300 Mbps. It's pretty bad, even considering that this is by wifi.
Today I did a reset on the router and now I have 50 Mbps. Outrageous.
The worst part is that I can't even send a proper email. Just call or depend on this forum.
What do I need to do to have what I'm paying for? A lawyer?
Hi @bassuino .  Like @EAZ1964   mentioned it is ESSENTIAL to measure via cable.
Here are a few things to keep in mind:
-Measure with the ookla app (can ben downloaded in Windows store)
-Make sure VPN is turned off
-Use a minimum of 2 pc's/laptops and make sure the ethernetcard can handle these kinds of speed
-Dont use an Ethernet to USB adapter
​​​​​​​-Powercycle both Router and Fibrebox.
If you still come up short, please let me know in this topic so we can do further analasye.
  • July 31, 2023
300 is a decent wifi speed in most situations.
As mentioned about 1000 times: 1Gbps is delivered to your router and can be achieved with a  computer connected with a cable to your router.
What makes people think that realistic household wifi speed = 1gbps ?
  • July 31, 2023
Thank you for your contribution to this topic EAZ1964! It was really helpful!
I'm pretty aware I'm not getting 1 Gbps on wifi. A sudden drop to 50 Mbps is just nonsense.
I also tested on cable and it reached 400 Mbps tops. KPN has clearly some issue on their side.
  • August 1, 2023
For the low incoming speed, unplug the router and modem from mains, wait a few minutes and reconnect. If still low, call the helpdesk so they can help.
  • August 5, 2023
