I switched to KPN: how can I connect my modem?
  • November 29, 2022
  • 211 keer bekeken
I had a Ziggo internet subscription so the old modem has a normal cable input
When I changed the internet to KPN ,They sent me a new modem ( box 12 ) that does not fit the cable input to the wall
This image is of the old cable income
Can someone help me
Beste antwoord door Remco van KPN
Hi @new modem! Welcome and thank you for joining KPN! I can understand the confusion but we use a different and separate connection than Ziggo. There should be another socket somewhere in your house. If you look on the page: Waar zit je aansluitpunt van KPN you can find a couple of examples. If you can't locate the connection point you can always contact us free of charge on 0800-0402 and my will then schedule an appointment for a mechanic.
  • November 29, 2022
  • November 29, 2022
Thank you for the reply, but I never have another cable entrance at home
RBxx
  • November 29, 2022
Hi @new modem
That connection is for Ziggo usage only.
For KPN you need to find the “ISRA’, which looks like one of these:
Or there might be glasfiber in your house. That connection looks like this:
@new modem Did you manage to locate our connection point?
