Instabiele verbinding, XGSPON defect?
  • August 24, 2022
  • 28 reacties
  • 1335 keer bekeken
28 reacties
  • December 2, 2022
Helaas, ik heb echt exact hetzelfde. Unifi Dream Router, met XGS-PON die elk uur ongeveer uitvalt.
In de logs van de UDR vind ik bij elke hapering dit:
2022-11-30T15:09:26+01:00 Router ubios-udapi-server[3735]: wireguard: Server Wireguard Peer (#1) has got peer 'xxxxx' (xxxxxxxx) disconnected
2022-11-30T15:09:26+01:00 Router ubios-udapi-server[3735]: signal-out-notifier: Sending to mcad: EVT_VPN_ClientDisconnected /vpn/wireguard/servers/1 xxxxx
2022-11-30T15:09:49+01:00 Router ubios-udapi-server[3735]: wan-failover-monitor-dns: wf-monitor-ppp0-3-dns (xxxxxxx->1.1.1.1) has dns-monitor update: 1.1.1.1:ui.com is down
2022-11-30T15:09:51+01:00 Router ubios-udapi-server[3735]: wan-failover-monitor-icmp: wf-monitor-ppp0-2-icmp (xxxxxxx->1.1.1.1) has dpinger update: 1.1.1.1 is down {"alarm":true,"id":"ppp0-mon2-1.1.1.1-ping.ubnt.com","latencyAverage":6429.0,"latencyStdDev":434.0,"lossPercentage":52.63159942626953}
2022-11-30T15:09:51+01:00 Router ubios-udapi-server[3735]: wan-failover-monitor-icmp: wf-monitor-ppp0-2-icmp (xxxxxxxxx->8.8.8.8) has dpinger update: 8.8.8.8 is down {"alarm":true,"id":"ppp0-mon2-8.8.8.8-ping.ubnt.com","latencyAverage":8575.0,"latencyStdDev":616.0,"lossPercentage":52.63159942626953}
2022-11-30T15:09:51+01:00 Router ubios-udapi-server[3735]: wan-failover-interfaces: wf-interface-ppp0 (xxxxxxx) is down [_DD___]
2022-11-30T15:09:51+01:00 Router ubios-udapi-server[3735]: wan-failover-group-base: wf-group-1-single is down [d](ppp0)
2022-11-30T15:09:57+01:00 Router pppd[3872]: No response to 3 echo-requests
2022-11-30T15:09:57+01:00 Router pppd[3872]: Serial link appears to be disconnected.
2022-11-30T15:09:57+01:00 Router pppd[3872]: Connect time 62.3 minutes.
2022-11-30T15:09:57+01:00 Router pppd[3872]: Sent 722198097 bytes, received 43909711 bytes.
Waarna ie weer een nieuwe PPPOE verbinding opzet, de poorten reset en weer verder gaat. Duurt telkens zo'n 30 seconden dat de verbinding weg is.
Heb nu de experia doos er maar tussen gezet, niet helemaal blij mee, maar de verbinding is iig stabiel
  • December 2, 2022
Kan je de "WAN failover monitor" ook uit zetten op zo'n Unifi Dream Router?
  • December 2, 2022
Ik heb die optie niet gevonden. Je kan wel een andere adres opgeven om naar te pingen.
Maar, voordat de wan failover monitor meldt dat de verbinding weg is, geeft de VPN server ook al aan dat de verbinding verloren is met de client. Ik zal de log in m'n eerdere reactie even aanpassen en die er bij zetten.
