IPv6 instellen Edgerouter
  • January 21, 2022
  • 22 reacties
  • 1224 keer bekeken
Hoi,
Ik probeer mijn edgerouter IPv6 adressen uit te laten delen op mijn LAN.
Echter lukt dit niet. Ook na verschillende fora topics bekeken te hebben en aanpassingen gemaakt krijg ik niet het gewenste resultaat.
Mijn Edgerouter ontvangt wel een IPv6 adres van het DSL Modem (experiabox 10).
De huidige config heb ik bijgevoegd, weet iemand waar het mis gaat?
firewall {
all-ping enable
broadcast-ping disable
ipv6-name WANv6_IN {
default-action drop
description "WAN inbound traffic forwarded to LAN"
enable-default-log
rule 10 {
action accept
description "Allow established/related sessions"
state {
established enable
related enable
rule 20 {
action drop
description "Drop invalid state"
state {
invalid enable
ipv6-name WANv6_LOCAL {
default-action drop
description "WAN inbound traffic to the router"
enable-default-log
rule 10 {
action accept
state {
established enable
related enable
rule 20 {
action drop
state {
invalid enable
rule 30 {
action accept
description "Allow IPv6 icmp"
protocol ipv6-icmp
rule 40 {
action accept
description "allow dhcpv6"
destination {
port 546
protocol udp
source {
port 547
ipv6-receive-redirects disable
ipv6-src-route disable
ip-src-route disable
log-martians enable
name WAN_IN {
default-action drop
description "WAN to internal"
rule 10 {
action accept
description "Allow established/related"
state {
established enable
related enable
rule 20 {
action drop
state {
invalid enable
name WAN_LOCAL {
default-action drop
description "WAN to router"
rule 10 {
action accept
state {
established enable
related enable
rule 20 {
action drop
state {
invalid enable
send-redirects enable
source-validation disable
syn-cookies enable
interfaces {
ethernet eth0 {
address 192.168.2.2/24
description Internet
dhcpv6-pd {
pd 0 {
interface eth1 {
host-address ::1
prefix-id :1
service slaac
prefix-length 48
rapid-commit enable
duplex auto
firewall {
in {
ipv6-name WANv6_IN
name WAN_IN
local {
name WAN_LOCAL
ipv6 {
address {
autoconf
speed auto
ethernet eth1 {
address 10.0.0.1/23
description Local
duplex auto
ipv6 {
dup-addr-detect-transmits 1
router-advert {
cur-hop-limit 64
link-mtu 0
managed-flag false
max-interval 600
other-config-flag false
prefix ::/64 {
reachable-time 0
retrans-timer 0
send-advert true
speed auto
ethernet eth2 {
address 192.168.2.1/24
description "Local 2"
disable
duplex auto
speed auto
ethernet eth3 {
disable
duplex auto
speed auto
loopback lo {
service {
dhcp-server {
disabled false
hostfile-update disable
shared-network-name LAN1 {
authoritative enable
subnet 10.0.0.0/23 {
default-router 10.0.0.1
dns-server 8.8.8.9
dns-server 1.1.1.1
lease 20000
start 10.0.1.10 {
stop 10.0.1.200
shared-network-name LAN2 {
subnet 192.168.2.0/24 {
default-router 192.168.2.1
dns-server 192.168.2.1
lease 86400
start 192.168.2.38 {
stop 192.168.2.243
static-arp disable
use-dnsmasq disable
dns {
forwarding {
cache-size 10000
listen-on eth1
listen-on eth2
name-server 8.8.8.8
name-server 1.1.1.1
gui {
http-port 80
https-port 443
older-ciphers enable
nat {
rule 5010 {
description "masquerade for WAN"
outbound-interface eth0
type masquerade
ssh {
port 22
protocol-version v2
unms {
upnp {
listen-on eth1 {
system {
analytics-handler {
send-analytics-report false
crash-handler {
send-crash-report false
gateway-address 192.168.2.254
host-name EdgeRouter-4
login {
user daan {
authentication {
encrypted-password ****************
level admin
name-server 8.8.8.8
ntp {
server 0.ubnt.pool.ntp.org {
server 1.ubnt.pool.ntp.org {
server 2.ubnt.pool.ntp.org {
server 3.ubnt.pool.ntp.org {
syslog {
global {
facility all {
level notice
facility protocols {
level debug
time-zone UTC
22 reacties
  • January 21, 2022
Bij welke provider heb jij een abonnement want zo te zien is dit niet KPN immers deze configuratie is niet geschikt voor KPN.
In het onderstaande topic vind je scripts voor de EdgeRouter waarmee de Experia/KPN Box vervangen kan worden.
Deze scripts configureren ook IPv6.
Of heb je jouw EdgeRouter achter een Experia/KPN Box staan en zo ja, welke is dat dan?
Edit: Oeps, je hebt de EdgeRouter blijkbaar achter een V10 staan.
Heb je VDSL, Sneller Internet Buitengebied of glasvezel?
  • January 21, 2022
Hoi,
Ik heb een DSL verbinding bij Youfone, dus de experiabox eruit slopen gaat helaas niet.
Jouw configuratie heb ik gister geprobeerd door te voeren, helaas niet met het gewenste resultaat.
Ook kan ik op internet geen/weinig informatie vinden hoe dit met een Youfone verbinding te configureren is.
VDSL, excuus, had geen aparte reactie hoeven plaatsen.
  • January 21, 2022
VDSL
  • January 21, 2022
VDSL
Zou je de V10 willen vervangen door jouw EdgeRouter door geen V10 maar een Zyxel VMG4005-B50 in full-bridge tussen de EdgeRouter en het ISRA punt te plaatsen?
De V10 doet wel aan IPv6 prefix delegation maar je krijgt wel een /64 prefix i.p.v. een /48.
Dit staat nu dan ook fout in jouw config.
  • January 21, 2022
Bedankt voor je hulp wjb, het lijkt het me leuk om IPv6 werkend te krijgen. Het is echter geen noodzaak en het is mij niet 100 euro waard.
  • January 21, 2022
Dan zou ik nog even tot 28 januari wachten want vanaf die datum is Youfone verplicht alle benodigde specificaties te publiceren.
  • January 21, 2022
Ah, oke. Dat was mij nog niet bekend, dan wacht ik dat even af. Is dat ivm met vrije routerkeuze?
  • January 21, 2022
Ja, dat is i.v.m. de vrije modem/routerkeuze.
Ik zie overigens dat Youfone dezelfde architectuur als kpn hanteert.
Zie deze pagina.
Dat zou betekenen dat mijn configuratiescripts zouden moeten werken maar alleen als de EdgeRouter de V10 gaat vervangen.
  • January 21, 2022
Dan ga ik is verder zoeken op Telfort configuraties, bedankt!
  • January 21, 2022
Zie de aanpassing van mijn vorige bericht.
  • January 21, 2022
Oke, alleen heb ik geen modem dat ik direct op DSL kan aansluiten.
  • January 21, 2022
Klopt.
  • January 21, 2022
Ik kan toch niet een PPPoe sessie opzetten achter de Experiabox, of zie ik dit verkeerd?
  • January 21, 2022
Dat zie je juist.
  • January 21, 2022
Zou jij in jouw config de prefix-length bij dhcpv6-pd eens op 56 kunnen zetten i.p.v. 48?
Krijgt eth1 een goed IPv6 adres?
Post anders eens een screenshot van jouw dashboard waarbij je het derde cijferblokje wegpoetst van elk IPv6 adres dat met 2a02 begint.
Voorbeeld:
Alle IPv4 adressen kan je rustig laten staan.
  • January 21, 2022
Heb prefix-length aangepast naar 56.
eth0 is mijn WAN.
  • January 21, 2022
Staat daar dan wel een slash voor?
Dus niet "prefix-length 56" maar "prefix-length /56".
  • January 21, 2022
Er stond eerst 56, heb er nu /56 van gemaakt.
  • January 21, 2022
En, enig verschil?
En wat bij /64?
  • January 21, 2022
Helaas niet, Eth1 en mijn apparaten hebben nog geen IPv6.
Een reboot is toch niet vereist?
  • January 21, 2022
Als het goed is niet maar niet geschoten is altijd mis.
  • January 21, 2022
Geen verandering.
