Modem Power light blinking
  • January 3, 2021
  • 325 keer bekeken
Good evening,
I restarted my modem and when I turned it on again only the power light is blinking and nothing more, I can’t even find my WiFi. What I can do?
box 12.
Beste antwoord door Shyrin van KPN
I'm sorry to hear that the restart didn't work. I will send you a new modem: you can pick it up at a PostNL servicepoint, at this moment this is the fastest way to get a new one. You will receive a confirmation by SMS and I have send you a direct message with information where you can pick up the new modem. Will you let us know if replacing the modem is the solution?
Bart van KPN
Hi @Skirmante, welcome.
I understand you don't have any services. That ain't nice. :( You already restarted your modem, but without succes. Have also tried to reset the modem? There's a litte pinhole on the back where you can reset the modem with a paperclip or something. If that doesn't work, will you fill in your profile so I can take a look at your line.
  • January 3, 2021
It didn’t work, I already filled it in ☺️
  • January 3, 2021
I already filled everything in and restarting the modem didn’t work
Shyrin van KPN
Forum|alt.badge.img+18
  • Community Manager
  • January 3, 2021
  • January 4, 2021
Yes, everything works now! Thank you
