No connection since start of subscription
  • June 27, 2021
  • 68 keer bekeken
Dear team,
I was notified that my signal was activated on the 25th of this month. I connected the modem today and the internet green light has been blinking the whole day and I do not have an internet connection.
I received a KPN Box 12, and I only found a landline socket in the house, to which I connected the grey cable to the DSL part in the modem.
I also have coax connections from which the signal from Ziggo was provided (I exchanged providers). Would it be the case of using a moca adapter? If so, does KPN provides it or should I buy it myself?
Hopefully there are no issues with my connection, since I need it for working.
Thank you in advance!
Hi @paula.feltes . Is it working again?
If not please contact 0800 0402. They can help you instantly.
2 reacties
  • June 29, 2021
  • June 29, 2021
Hey @Erwin_ ,
thanks for following up on my post. It isn’t working, unfortunately. I called the customer support service and someone will come over tomorrow afternoon to try to solve it. Hopefully it works out!
Â
