No internet connection
  • January 4, 2021
  • 117 keer bekeken
Hi,
I just installed the modem, the wifi is on but there is no internet connection. Can you help me with this situation?
Thank you.
Best,
Nana
@Rutger_ Did the mechanic fix your problem?
Rutger van KPN
@Nanaratna Welcome to our forum.
 So you followed the instructions on our installation page but there is still no internet. I would like to check what I can do for you. Could you fill in your forum profile and let me know when you did?
Then I can retreive your information and check if everything is okay!
  • January 4, 2021
Hi @Rutger_ ,
I have filled the information. Thank you.
Rutger van KPN
@Nanaratna Thanks I see that in this case a mechanic has to come to you.
He will be there tommorrow between 10:00 and 12:00. If that is not okay, can you let us know as soon as possible? Then we can rearrange te appointment.
Rutger van KPN
  • January 13, 2021
  • January 25, 2021
Hi sorry for the late reply, he did! Thank you.
